Andrewwright
im looking for a good front light, one that lights up where I am going, bought so many lights which are bright, but don't light up the road, has any one any suggestions
Any discount for bulk purchase?I have used lights which take 18650 batteries for quite a few years now.
Nowt proprietary about their vision 1 roubaix.Hope lights are great bits of kit. I was considering picking up one second hand but i didnt like the fact that the lights had a proprietary connector which limits you to using batteries from Hope only unless you cut a few cables and modify it to take battery packs from magicshine or the generic ones off ebay etc etc
It is roubaix i assure you. A fair few folk on here use it for that. I have used jt on past dynamos. It has the great advantage of being totally self contained and uses AA batteries. Changing batteries mid ride is a doddle. Have also used it on a solo ride london to cambridge and back. All fine.Im obviously referring to their R2, R4 and R8 series of lights. I dont think the Hope 1 is quite bright enough for unlit roads if youre out there just on your own.
If you're posting this in Touring, have you thought about investing in a dynamo system? Fewer watts than the Nuclear-O-Matic battery lights, but the lamps tend to be designed with better lenses and reflectors and generally a lot more effective at getting the light on the road not into the heavens or hedgerows. Also no worries about running out of batteries
