Front mech not throwing chain onto big ring
wisdom
Blackpool
Sons bike is an oldish giant boulder with mid range shimano gear.It's no longer shifting up onto the big chain ring.Cables very tight and there doesn't seem to be any more movement on the front mech.It was working ok until last week.Any ideas please.
cyberknight
Does the H screw need adjusting ?
pclay
Rugby
It may have siezed. If it has, liberal spray of wd40, or take off and soak in olive oil overnight.
Tim Hall
Crawley
As it used to work but now (suddenly) doesn't, I'd be looking for mechanical damage. Has it had a knock? Is it parallel to the chain rings? Is the cable damaged? Perhaps frayed where it leaves the shifter.
wisdom
wisdom
Blackpool
Thank you all for your replies. It would appear one of his mates adjusted it for him at work.Adjusted it so much that the H screw was screwed right in.I have advised him accordingly
  • Like
Reactions: gbb
gbb
Peterborough
That's a common "Solution" applied by people who only have a scant knowledge of cycle mechanics. First sign of rough shifting start fiddling about with the stops, the very things that never need adjustment after the initial setting.
Agree wholeheartedly. It's the LAST thing I consider, stop screws just don't un adjust themselves IME
