Can anyone offer any suggestions. I'm only getting about two and a half hours use from a full charge. Back light turned off, not using hrm or cadence and not using maps screen.
Dear <jefmcg>,
Thank you for contacting Garmin Europe.
I am sorry to hear about the problems you are having. I will be more than happy to send out a new HRM to you. Please can you confirm your best address details and I will arrange this.
If there is anything else I can help you with then please let me know.
If you've replaced the battery it could be the failure of some circuit board component. I only say this because an old Etrex of mine, developed a USB connection fault which also brought the 2xAA NIMH battery life down from ~24hrs, to <3hrs. Contacting Garmin may be worth a shot.
I know you've mentioned this, but are you sure the backlight isn't on? I used to struggle with the battery life on my 810, and thought I had the backlight off, but if you press the on/off button (as I'm sure you know) it actually turns the backlight back on, and in daylight it's pretty hard to tell if it's on or off. It's the only thing I've found which reduces the battery life significantly.
