Garmin Edge 810 Question
junkie_ball
Somerset
Hi,
I'm going to be using my 810 to do a long ride this weekend. This will be the first time I will be riding a route i'm not completely sure of. I have uploaded the route as a course on the 810. My question is if i navigate using the course i have uploaded and i change the screen from the map to my normal data screen (speed, time, cadence etc.) will the turn by turn directions still pop up on the screen when i need to make a turn or do i need to keep it on the map screen to receive the turn by turn instructions?
uclown2002
Harrogate
On 800 you can have it on any screen you like. As you approach a turning it will auto switch to show you where you need to go. You can then 'tap to go back' to previous screen.
jazzkat
Fixed wheel fanatic.
It should do, mine gets a bit glitchy sometimes and forgets to tell you to turn until you actually make the turn (or go off course). I'm hoping that recent software updates might have fixed it.
