Inner tube question.
esoxlucius
Just got a puncture on my bike and when I took the inner tube out it was a "700x18/25 thin".
I already had some 700x18/25C inner tubes so put one of those in as a replacement. They "seemed" quite similar.
But now I'm second guessing what I've done and need a bit of reassurance. Is the replacement ok, or do I really need to be replacing it with a proper "thin" one, like the one I took out?
Thanks for any advice.
N0bodyOfTheGoat
Hampshire, UK
I expect the "thin" was a super light variant, for example like Continental Supersonic tubes.
If the new tube matches the tyre size, or isn't much smaller than the tyre size, it will be fine.
esoxlucius
esoxlucius
Just did a bit more digging. Apparently the "thin" tube is indeed a bit of a "sportier" type tube, a little thinner and more lightweight than a standard 700 18/25C. The bike is a Merida Reacto, an aero bike, so the lightweight sporty tube is supposed to offer marginally better performance.
Looks like my performance is going to nose dive now I've put a tractor inner tube in instead of a proper one, lol.
si_c
Wirral
You'll likely spend another second or two on a 50 mile ride. Hardly worth worrying about performance tubes unless you race - my primary criteria is how many I can get for a tenner.
albion
Gateshead
I recently made use of oversized(width) tubes, in the knowledge I now have a thicker understretched tube for less air leakage and marginally more puncture protection.
