It comes preloaded with a hell of a lot of junk which I'm trying to dump/disable... god knows how many geocaches and different maps which I can't see me ever using, along with several 'profile' screens which I really can't see the point of. There is the option to use 'classic view'.. but that defeats the point of getting a newer one.
There's an option to change the order of the items in the main menu. Put the stuff you want (eg Track Manager and Waypoint Manager) at the top and then just leave the rest alone. It might come in handy one day - or you might never use it. Either way it's not going to cause you any problems. Ditto you can select which items you want show in the Page Sequence - I have Map, Main Menu and Satellite in mine. These mean you can flick easily to the bits you want.
I'd concentrate on working out how to use the features you want to use - eg it's worth spending sometime going through the setup options - eg units, screen brightness, backlight timeout, track recording intervals and a few more. The other set of important options are under map setup: zoom levels controls whether waypoints are visible or not, data fields controls things like the display of speed and time. It's also worth spending some time with the Find menu to find POIs.
And as always, and I know this is boring advice, but it really is worth spending time reading the manual. Yes I know where's the fun in that? But it's cheaper than selling the device at a loss because you haven't taken the time to read the instructions.
