Gasket Sealer
twentysix by twentyfive
Clinging on tightly
Over the Hill
Hello knowledgeable folks.
I think the gasket between the carburettor and the cylinder block on my two stroke engine may be leaking. That bit gets fairly hot. I don't think I can source a new gasket as the engine is no longer "supported". So does anyone have a recommended hot gasket sealer for this situation?
TIA
Dirk
If 6 Was 9
Watchet
TIA
What's the engine?
Stompier
Looking online, the OEM part looks like a composite gasket, so it's probably worth replacing it with a new one. The gasket shape looks quite complex to replace with a silicon sealant or jointing compound without making a mess.
Dirk
If 6 Was 9
Watchet
It's a chainsaw one. Jonsered CS2137 Not sure how I can extract engine details from that.
I've just been googling and gaskets are available for the CS2137 but before I spend even more dosh on this thing I'd like to do a cheap sealant type job first to see if that solves the problem.
Plain cardboard gasket smeared with grease would do the job.
Cut one out of a Cornflake packet.
Dirk
If 6 Was 9
Watchet
Do you think he could get away with a Rice Crispie packet gasket?
Even better. It will restore the snap, crackle and pop to his 2 stroke. :okay:
Moodyman
This should do it for a fiver from Euro Cat Parts:
