junkie_ball
- Somerset
Ok so i take my bike to the bike shop to have a service and generally tighten things up. This bike has only covered approx. 400 miles and the gears was not shifting overly smooth so was hoping the service would cure it (i made a point of informing the bike shop about the gears). Up on collecting the bike from the bike shop i find the gear change from the small chain ring to large on the front is very sluggish and non existence when in any other chain ring apart from the smallest 2 or 3 chain rings on the rear. Which if anything is worse than when it went in.
Ok i think give the bike shop the benefit of the doubt as have used them in the past without any problems with other bikes. I take it back and and they double check them now they say the indexing is correct but the cables have rusted under the ferrels and so needs replacing. This seems very suspect to me as I've only covered 400 miles on the bikes and i always make a point of cleaning and drying the bike after each ride. Ok i appreciate i have been out on this bike in the rain but can't believe the cables need replacing especially not for the £40 they want to charge me.
I haven't inspected under the ferrels myself yet but when i do if i find they are slightly grubby / rusty would a bit of wire wool and lube help ease the problem. Any views or ideas on this would be appreciated.
Sorry for the rant and long post. If you made it this far thanks for sticking with it until the end.
