ChrisEyles
- Devon
I'm currently running the 48/38/28 crankset and 11-32 8 speed cassette that came with my current bike (11-13-15-18-21-24-28-32).
Mostly I get on with it very well - I love the "sensible" gearing for tackling some of the 15%ers around me, and I'm certainly never going to run out of gears at the top end.
However, there are two minor issues I'm currently having
1) The top gears are far, far too widely spaced - especially given you only use these when going pretty fast with a lot of wind resistance, it's hard to pick the perfect gear
2) The gears that see the most use in rolling rides and town commuting are the 38/15 and 38/18 cogs. When I'd like to up the pace a little, I've got the choice between 38/13 (which seems a bit of a small-small combination in terms of the number of teeth on each cog, and suffers from a bit of cross-chain on my set up), or 48/18 (only a small step up from 38/15, and then the next 48/13 gear is too big a jump, plus I'm constantly having to shift the front and rear together)
What I'd like to achieve is:
1) A closer spacing of gears at the top end (which needn't be anywhere near as high as it currently is - I think I could get by with 48/14 just fine)
2) Being able to stick in either the middle or top chain ring, using only the cassette to change gears, around my usual cruising speeds.
My first thought was a 14-32 (custom built) cassette - this would solve the spacing of the higher gears, but not the need to switch from 38 to 48 a lot when commuting...
Alternatively, I could look at changing the chain rings... I have a 53/42 crankset on my road bike, and love the 42 ring (but not the 42/26 low gear!), so maybe I could change the chain rings to something like 53/42/30 (assuming this is possible).
Any suggestions or ideas would be more than welcome
Cheers!
Cheers!
