GuyBoden
- Warrington
If I was only cycling a few flat miles locally, a single speed would be fine and less/easy maintenance..............
Depends where you live. IFor a utility bike no more than 3 gears is fine. Maybe even single speed if you really want to keep ir simple.
Fixed that for you.Depends where you live. I wouldn't want to ride up some local little hills, fully laden with shopping with only one uphill gear to choose from.
I am using a Sturmy Archer 2 speed kickback hub for rides of up to 40 mile, with a low gear of about 50 inch and a high of about 70 inch, I find it OK as long as there is nothing too steep to get up.
It gives you a bigger range of more closely stepped gears.What can 10 gears do that 5 cannot?
My AW hub is ideal for south Birmingham with its 80, 60 and 45 inch gears. London is flatter so I reckon you should be OK with a 5/6 speeder. I'd use the chainring that give the best chainline.
If used correctly, it's handy to have identical gears as it lets you pre-select the chainring needed.When you look at the ratios on a lot of bikes with a high gear count, what you find is ratio duplication, or ratios that are so close as to be pointless - such as two gears that are only an inch or two different.
Yes - and Birmingham is on a plateau, with one or two big lumps on itWhilst most of London is fairly forgiving, gradient-wise, it nonetheless does have a number of locations where having to get off and walk up is a real possibility if your bottom gear is relatively high. It's a fallacy that London is flat, just in the same way Norfolk isn't flat either.
