Glass/Windscreen Cleaning
  • Thread starter Deleted member 26715
  • Start date
I have to bond a windscreen onto a fibreglass surround I tried it once with Tigerseal but due to flexing it has come away from the glass. Perceived wisdom is I didn't get the glass clean enough, somebody has suggested thinners but I didn't think you could buy it anymore? Another is Acetone any idea where you get it from?
Mark pallister
Is acetone not just nail varnish remover ?
isopropyl alcohol is what I’d use
Sharky
Kent
Acetone you can get from a chemist. I use acetone to remove my rubbers. Don't know how much you could buy. I only use a very small quantity.
Table tennis rubbers.
slowmotion
Quite dreadful
lost somewhere
Glass merchants usually stock a specialist aerosol that they use to clean glass before they make up sealed double glazing units. I used some a long time ago and it's demon stuff. Try your local merchant.
Thanks all got some om order, bought 1L but can see me having loads left
Lookrider
Edit:- Looks like Amazon is the obvious place
If you dont want to shop online you can get IPA at maplins as it's used for cleaning electronics due to its evaporating quality
Like others I used it for cleaning disc brakes ...first asked a couple pharmacies who said they do not stock it as you need a license because of the alcohol content in it
Maybe they did ..sorry
Ah okay, I just thought you knew something I didn't, I used to know a few people who worked for them at the Head office & thought they all had lost their jobs.
