Last maplin shop closed in June 2018, still seem to have an online presence though
https://www.maplin.co.uk/
If you dont want to shop online you can get IPA at maplins as it's used for cleaning electronics due to its evaporating quality
May I ask what type you use, I have been advised to use Dinitrol 500 with prior use on Dinitrol 530 (I think)I bond glass to glass using UV adhesives for bespoke shower enclosures & use Isopropyl alcahol, available cheaply online.
1001 uses elsewhere as a degreaser/cleaner. Many glass adhesives also require a specialist primer to improve bonding
AmazonWhere do you get that from?
That's just for general streak free window cleaning, but i don't think the newspaper trick works anymore as the active ingredient was the old newsprint ink, which is more inky and less sooty these days.White vinegar and newspaper?
😄 My eyes were watering long before I found the last line!Acetone you can get from a chemist. I use acetone to remove my rubbers. Don't know how much you could buy. I only use a very small quantity.
Table tennis rubbers.
