lane
I have been running GP5000 for about 16 months and completed approximately 6,500km . I have been keeping an eye on the wear indicator and knew that the tyres might need replacing soon. Yesterday when out riding I had what might have been my first puncture; I heard a a noise that sounded like the sealant leaking out, I kept riding in order to spin the wheels and get the sealant to the puncture, in a few revolutions the noise stopped. I rode slightly further and stopped to examine the tyre. I couldn't see where the puncture had been but the tyre had lost pressure, so I pumped it up a bit and then continued a further 40km home with no issue.
I checked the tyre this morning (rear wheel) and the wear indicator is no longer visible so in theory it needs replacing. This may have been the only puncture I have had and it has occurred when the tyre is quite worn. I have not had to repair a puncture in these tyres. I have had no real problems, albeit a bit of learning curve with tubeless but have got it sorted now and know what I am doing. I don't have any issue taking the tyre off the rim and re mounting. I can easily inflate and mount with my track pump and indeed with my frame pump. I have had a slight problem with my valves gumming up making them harder to inflate. I switched from stans racing sealant to Effeto Maripose Caffelatex sealant because the later can be put through the valve rather than taking the tyre off, and i am pleased to say that it sealed the puncture fine yesterday. I also hoped it would lead to less valve gumming but not sure this has been the case.
The front tyre does not need replacing yet, but looking at the wear indicator I would be surprised if it lasts much beyond another 2,000km and maybe less.
Looking at the back tyre it does have some cuts in it but nothing to concern me.
I have used the tyres on lots of lanes and also a fair amount of gravel / poorly surfaced tracks. This may have impacted the wear rate.
I don't know what mileage people expect out of these sort of tyres, but they have worn more quickly than I would have liked. Malcolm at the cycle clinic has also commented that these tyres seem to have a high wear rate; although he says that they are good tyres if you can live with the wear So I don't really know if 6,000km is poor or not for a rear tyre and possibly not a great deal more for the front. When I look on the web there are so many different figures I suspect mileage is very variable and dependent on may variables making it a bit hard to compare.
So would I use them again? Yes i am going to replace like for like without having to give it much consideration. I am sorted with tubeless; the tyres are comfortable and fast; I have not had to mend a puncture; they have coped with a variety of surfaces including off road / gravel. My only reservation is the wear rate seems high but they have lasted me 16 months at the mileage I do so guess I can live with that.
I run 32mm.
I run 32mm.
