Alien8
Senior Moment
- (A little bit north of) Cambridge
But as aforementioned, range-rate between two points on an undulating surface will differ between a line drawn in 3D space between the same two points. Even assuming both devices were 100% accurate the results will still differ, because they're measuring different things.
I don't get your point @Drago, GPS measured range-rate is an instantaneous measurement of the frequency shift in the received signals - differences in position, straight-line or otherwise, has no relevance in this respect and has no impact on GPS measured velocity.
Anyway, as has already been pointed-out elsewhere, there are a myriad of factors that can influence the velocity as displayed to the user and hence any perceived difference, wheel-revolution-counting vs GPS, is probably not worth worrying about.
