A slight exaggeration?
If moderately fit cyclists on carbon bling with doubles insist on falling over on hills in front of me, I'd suggest they needed a triple, even if it does hurt their vanity.
No. You've obviously got an incident in mind.
I wasn't there, but seems to me at a guess that they can't have been moderately fit and were probably turning a 42 at the front and a 21 at the rear. Or similar.
I've just done a quick bit of checking. A small triple chainring with 30 teeth with a 25 at the rear gives a lowest gear of 31.7. And 23 teeth at the rear gives a gear of 34.4 and 21 at the rear gives a gear of 37.7. A compact chainset with a small chainring of 34 teeth with 25 at the rear gives a lowest gear of 35.9, somewhere between the second and third gear of the triple chainring. A 34T with a 28 cog at the rear will give a low gear of 32.
So the triple in reality gives just two additional lower gears. Useful maybe (say) 1% of the time, on the steepest bit of the steepest hill, and even then you might be looking for an even lower gear. So to the question - do you "need" a triple to do a Sportive or long leisure rides, the answer is no.
There is only one real advantage in my view to a triple (other than the occasionally useful two lower gears
) and that is with a 52/42/30 chainring, the ratios will be much closer together than a 50/34 compact.
