Grease for seat post?
colinr
Norwich
I've got grease (called Seriously Purple Grease) that my LBS provided for pedal threads, is that stuff ok for the regreasing a seat post (as in, it's not going to result in the seat post slipping inside)?
It's an alloy seat post in an aluminium frame.
hubgearfreak
copper grease would be a bit better, but if you plan to re-do it annually any grease will be fine. don't go buying a new tub just for that job, and don't leave it too long. they really are a devil to remove when they're seized in:angry:
jay clock
Massive member
Hampshire UK
Grease will be good, just a tiny bit. Take it out once a year, or at least undo and turn it. I had an alloy one seize in a steel frame and it took a bike shop to drill it out
Steve Austin
The Marmalade Kid
Mlehworld
Any grease will be fine for an ally post in an ally frame. I would remove and regrease a little more frequently than annually though, because once its seized, they are a bugger to remove.
02GF74
hmmm, on some bikes I have used it without any probs but on 2 the post slipped ; i removed it and it is fine. take your pick.
