Halfords sold me a 20inch frame...I'm 5ft 5
sarahale
I don't really want to shop with them but I want a voodoo mtb. Got caught up with everything and I'll be honest I don't know that much. So I pootled round the shop on their display and they said yeah that's perfect for you. So I ordered one.
When I got home I then thought about it, I'm a small 5ft 5. So will be ringing them tomorrow to find out if I did actually try a 20" or if it was an 18" because I'm certainly not between 5ft10 and 6ft1 like their size guide recommends.
I know its my fault for not knowing much but still.
Dave Davenport
Hampshire
If I had to guess, I'd say you'd want a 16".
simon.r
Person
Nottingham
I'm 6'2" and ride a 20" MTB.
Different manufacturers geometry will vary, but a 20" frame for someone your height would seem to be a tad on the large side:ohmy:
sarahale
sarahale
Would the fact that its 26" wheels make any difference? My current ride is a specialized hardrock 18" which is fine and comfy
Learnincurve
Chesterfield
I'm 5"6 and ride a 19" MTB with 26" wheels because I have such a long in-seam (32.5", you measure from your crotch to the floor. ) in a 29er I might be 17" but even then I may have to scale up because my arse could end up in the air.
You deffo need 16"
summerdays
Cycling in the sun
Bristol
I'm 5'5 (and a little bit) and I've got both 17" and 19" frames but I wouldn't want to go any larger than the 19", as I get older and stiffer it is starting to feel a little too big sometimes.
sarahale
sarahale
Its a voodoo hoodoo with 26" wheels.
They have ordered me a 20" frame as that's apparently the one I tried on shopfloor and it was fine, slight reach to the floor but putting saddle down 1cm would be enough to solve that. Convinced I tried the 18 looking back.
