Handle Bar grips/Dropper post
MonsterEnergy
I am needing some handlebar grips, but can someone help me how to measure so i can get the right size grips.
Same with dropper seat post. How do i measure the seat post so i can get a new one?
Be glad of your help
Hacienda71
Grips are pretty much universal. The dropper is more complicated. You need the seat post diameter of your frame. It should be in the spec of the frame if you Google it. You also need to check the routing of the cable. Unless speccd for a dropper, you will probably need an external routed cable. You also need to see how much post is showing and how much can go in the frame to decide how much drop you can use. You don't want a dropper which is too long to use. I am sure someone will be able to help with the detail.
T.M.H.N.E.T
Northern Ireland
Dropper shouldn't be critical, just take a centre BB - saddle measurement and set height with dropper extended.
I don't know the market now but I had to use a sleeve on mine to upsize to the frame, at the time the options were limited though
MonsterEnergy
MonsterEnergy
What do you mean by universal?
How do i measure it, as there are loads of different sizes of grips.
MonsterEnergy
MonsterEnergy
I'm not as bothered about dropper seat post tbh.
I'm wanting to keep the same seat post, but just wanting a new comfier seat for longer rides, and mtb.
Anyone suggest how to measure just the seat
iluvmybike
Most modern mtbs have the same diameter for grips - it's best to get the lock-on type so they stay nicely in place. Beyond that it is a question of what colour & how much you want to pay
Don't worry with the grips. Planet X sell some good cheap lock on - I prefer lock on as they are easy to fit and remove when they wear out. They are all the same bar diameter, and most are 125mm to 130mm long, so any will do. Don't get white.
Can you post a picture showing how high your seat post is for normal riding. - As others have said you may be liited if you've got your seat quite low. Yor are looking at in excess of £100 for a dropper - Brand X are around that.
MonsterEnergy
MonsterEnergy
i will post a picture later, but it's in line with the handle bars
