I've been doing some measurements in an attempt to work out what BB I need to buy for the Royal.
2017-09-03_04-08-56 by RichardB5, on Flickr
In the above picture I have the chainring on the inside of the spider on what used to be a triple, and a small chainring on the outside to act as a spacer. The bottom bracket is the original, which was about 117mm I think.
Working on the assumption that it seemed ok like that I bought short chainring bolts to let me run it as a single, and a 110.5mm UN55 BB to compensate for the chainring's new position.
It looks a bit better but the chainring bolts are very close to the chainstays.
It was at this point I decided to do a proper job and take some measurements.
The OLN measures at 122.5mm and it's 16.5mm from the inside of the drop out to the centre of the sprocket. I make that 44.75mm from the centre line of the frame to the centre of the sprocket.
The centre of the chainring to the other side of the seat tube is 56.0mm and the OD of the tube is 28.8mm. I make that 41.6mm from the centre of the frame to the centre of the chainring.
I think that means I need a BB that protrudes 3.15mm further than the one I have, which is 6.3mm overall length. As the existing BB is 110.5mm I think I'm looking for as close to 116.8mm as I can get, which would be 118mm if I get a UN55 again.
Does that sound right or have I got it all completely wrong?
