First
to Cycle Chat.
Like these
decent overshoes, perhaps?
Don't quite know what you mean by 'oversized'. These Enduras are a tight fit (zip at the back). A loose (oversized) fit would interfere with the cranks.
Thanks for the welcome
A bit confused by your reply, seems you are quoting yourself. But anyway.
What I meant to say is just use a watersports neoprene bootie as a shoe over a merino sock. Oversized to the point that the sock fits with a bit of room to spare.
I guess the problem with these is that the sole is pretty thin because they are meant to be flexible to fit inside a kayak hull where any more traditional sole would have a tendency to get stuck. Might be too thin for cycling application.
Neo Sport Wetsuits Premium Neoprene 3mm Low Top Pull On Boot, Black, 9
https://www.amazon.ca/dp/B000LK1O8Q/ref=cm_sw_r_cp_apa_KO6uAbQV7A30S
Another thing paddles do is a completely soft neoprene sock inside a large sneaker or sometimes even a sandal. Layered under neoprene.
I do have a feeling hovewer that with my tendency to get cold I need an active source of heat on my toes. Yesterday, I did fine everywhere but my big toes. If if wasn't for these I could have gone an entire day in windy -10 but the toes were killing be after an hour. I guess insulating something that produces no heat only goes so far
