Profpointy
And me.
It's more precise* than Celsius.
*Note: I said more precise, not more accurate. So don't start....
eh - why's that then?
And me.
Celsius has 100 degrees between the freezing and boiling points.eh - why's that then?
But adding a decimal point when higher accuracy is needed covers that in both scales. The only difference in precision is the measuring, not the scale. You might need an extra decimal added more often (9/5ths of the time?) in Celsius but if it's that kind of precision you need, that's what your thermometer will get.Celsius has 100 degrees between the freezing and boiling points.
Fahrenheit has 180.
So for any given level of precision, the Fahrenheit temperature will always define a smaller range.
I did say "for any given level of precision"....But adding a decimal point when higher accuracy is needed covers that in both scales. The only difference in precision is the measuring, not the scale. You might need an extra decimal added more often (9/5ths of the time?) in Celsius but if it's that kind of precision you need, that's what your thermometer will get.
a 60 year old oak tree drinks up to 50 gallons of water a day. So if they hadn't chopped all the trees down i suppose they wouldn't have to worry about millimetres and litresRoger Harrabin, discussing flooding: "here's a statistic I've only just heard: for every millimetre of rain that falls, that's an extra litre of water on each square metre of ground."
Makes you proud of our science education system, doesn't it.
If you want to add a decimal place to a Celsius measurement then you should the same decimal place to the Fahrenheit, and it will still be more precise.
My morning pot of tea involved raising the temperature of the water to 671.64102 °R*. There's a lot of decimal points but there's not much point really because the kettle simply switched itself off when the water was boiling.I was afraid you might say that. So feet are more precise than metres then in your world . oh well
Ta! And the tall bits have white stuff on top...![]()
TOP TIP
I cracked temperature conversion.
28c = 82f
16c = 61f
Easy reversal of numbers.
You only need to know these two numbers: Anything below 16/61 = a bit chilly , anything above 28/82 = a bit hot . In between it is lovely!
He is probably having to spell it out for all the Arts graduates who staff the Beeb. For example, they had a recent story about a naval submarine "trapped under hundreds of feet of Arctic ice" - that's just pig ignorant, and I did Classics!Roger Harrabin, discussing flooding: "here's a statistic I've only just heard: for every millimetre of rain that falls, that's an extra litre of water on each square metre of ground."
