Heat pump experiences
OldShep
As far as heat pumps go
our main concern is 2 fold
a) I don;t think the insulation in our walls is good enough
and I do not know how to check - or for that matter upgrade it without massive work
b) we do not like the whole house to be the same temperature - we lik ethe bedroom to be cool and the lounge to be warm
and heat pumps seem to want to make the whole place the same
You need to know how much heat your home leaks and then size your pump to that. If you are using gas purely for heating then you’ll have years of bills giving an idea of how much energy it takes to heat your home.
We have only ever heated our main living area and let heat leak from there to other parts of the house. I know if it’s 0 C outdoors then a 2Kw electric fire will hold the indoor temperature and be a long time increasing it. Putting on another Kw will increase the indoor temperature and then I can go back to 2Kw.
Armed with this knowledge I fitted a 4Kw AC unit 15 years ago and my estimation worked. The age of that unit it did need supplemental heating below freezing.
This year I’ve renewed it with a premium r290 model 3.5Kw and a A+++ rating. Able to work down to -30C These units have certainly improved over time and the comfort level has doubled.
Looking at depreciation the old machine worked out less than £100/yr. Service costs were nothing more than hosing down the outside unit once a year and a bottle of AC cleaner. Regular washing of indoor filters. All in no more than a couple of hours of my time a year.
Gas is not an option where I live. Operating costs the last week on 24-7 keeping the house between 19 & 22 I’ve used 39Kw
Milzy
Joule cylinders, banging, cracking, rattling & leaking. Who’s got one?
mjr
do any installers give a guarantee about the savings
or at least no increases
the article that you see either say you will save LOADS
or are horror stories about people who are no paying loads more than they were before
which is just confusing
I think there are some installers who will guarantee the performance/efficiency as long as you don't change certain settings. No-one will guarantee no cost increase, as some morons would then turn the thermostat up to 28°c and open windows, then try to claim!
dicko
Derbyshire
21st October, Octopus Energy app down, heat pump owners can’t control their heat pumps as they are controlled by the app.
dicko
Derbyshire
The Octopus Energy app is still not working and if the heat pump is controlled by the app your in trouble. Why oh why must it be controlled by an app surely a in house controlled would be far more suitable?
mjr
A victim of AWS unplugging the wrong lead?
No, it looks more like a buggy app version 4.101.0, which I'm told has been removed from the app store. Downgrading to version 4.100.0 might help.
You don't have to use the app to control the heat pump. The controls are also available on the Octopus cloud API, so there are semi-independent apps like "Octopump" for iPhone, or add-ons to HomeAssistant and other control systems. However, that is still using the cloud so relies on internet access. I don't remember whether there's a local network API too, as I've not got one.
