Fab Foodie
- Kirton, Devon.
Fab!yes... it's where i found the 'cheap generic part'
It's where I find most of my appliance spares ....
thanks for pointing me to itFab!
aye... i suspect that's the case.
Problem is i can't find the exact part in stock anywhere, but can find a very cheap generic part with looks like it should do the job... but I'll have to drill a new hole in the back of the machine as the screw fixing plate is different.
edit... there's this which looks like it has a fixing plate similar to what i need... yeah it says 'Servis' and I'm after a part for a Hoover washing machine, but a solenoid's a solenoid, right?
another edit... in fact, looking at the dud valve i've got, i reckon i can remove the fixing plate with a bit of brute force and fit it to a generic replacement
if you've found the actual part i need in stock somewhere, I'd appreciate a linkPart Number & model number(machine). Found both for the model number given in your Good Friday thread, priced at just over £20.
You're correct in saying its just a solenoid, but never that easy.
Voltage used to operate can vary, as can the direction. Possible causing bigger problems.
no the sticker it's got:What's the machine model number? I'll check the local service agent on Tuesday.
Why do you need the hot feed pipe?no the sticker it's got:
AC110 001
n: 37613734 9842 1510
Dunno if the long number is required, Google thinks it's a phone number
and the part number for the hot water valve, according to the service manual, is 97910525
I have plumped for the generic one at a fiver on amazon and should arrive later this week, but if that doesn't do the job I'll still need to source the actual part... so your kind help may well be needed.
Do you know what sort of voltage range these things operate at? Can a working solenoid be triggered with say a 9volt battery?
I'm sure when the downstairs neighbour reads this, they'll feel mightily relieved that Monty and Classic are on the case.I CBA to read all that, can't you just get another one that works.
Could just turn the water off for the time being though!I'm sure when the downstairs neighbour reads this, they'll feel mightily relieved that Monty and Classic are on the case.
oops, copied the wrong number, try 92202853... I'm off to specsavers! edit... maybe not, it's pea soup outsdideWhy do you need the hot feed pipe?
http://www.applegate.co.uk/b2b-products-services/1f8887908e8611e395ed005056822514.html
