Stu Smith
- Lancashire
Hi all,
Recentley pulled my winter bike back out..
To find the gremlins had been at it. When the bike was put away all was working fine, no problems whatsoever.
First outing the gears where slipping. Typical problem I can set it up and the gear change will be fine for the fist 4 cogs and then slip on the next cog, I then adjust so as not to slip then it will not change into the very bottom cog (Smallest cog). Only turning barrel adjuster 1/4 turn each time.
List of things I've done to rectify to no avail.
1/ New inner and outer cables fitted and indexed correctly - Still slipping.
2/ New rear hanger fitted, re indexed - Still slipping
3/ Had a brand new rear derailer fitted and set up - Still slipping
4/ Made sure the back wheel is sitting in the dropouts correct. - Still slipping.
Its not a regular slip sometimes I can ride using all gears for 30 - 40 mins and it will work fine, then all of a sudden I will change gear and I will get the slipping and the chain wanting to climb up onto the next ring. Stop adjust and will be fine again for a little while..
