Joe24
- Nottingham
MacBludgeon said:Okay guys, I'm going to build one, I currently have two steel frames with horizontal drops, one will be a tourer/backup commuter and the other a fixed. So I'm looking at my gearing and would like to be able to do my commute(40 miles) on it. I'll go with toe clips to start with, also can you get a fixed/fixed, flip-flop(is that the right term?) rear wheel, different size cog each side?
At present I have two sharp hills on the commute, fairly short, where I drop to the 44 inch gear. I have a couple of longer ones where I drop to 54 inches. Most of the ride is spent in the 60/67/76 inch gears, I do go higher for a couple of downhills. What I don't want to do is spend time pushing, so I'm thinking of a 60 inch one side, to get me started, and a 66 inch on the other side for when I get fitter. It'll take me a while to put together anyway, so hopefully will be fitter by then anyway. I keep aiming to have a higher bottom gear in use, as I improve, anyway.
So what think you folks?
Somewhere around 65" will do you. Its a nice gear to go up hill on, a mate of mine went around Derbyshire/ the Peaks in this gear and would go up any hill.
You will be fine on it, no need for the smaller gear on the other side. Get good at spinning this gear and you will be well away. I know someone that ran 63.5" and could beat people down hills on geared bikes
