potsy
Rambler
- My Armchair
Will these cassettes be compatible with my Trek 7.1FX?
http://www.chainreactioncycles.com/Models.aspx?ModelID=38302 1st is a Shimano HG50,2nd is Shimano MF-TZ07 freewheel cassette(is this different from the 1st?)
http://www.chainreactioncycles.com/Models.aspx?ModelID=46861
As you can tell I'm a bit newb when it comes to this.
Cheers.
3rd is a Shimano HG30-
http://www.chainreactioncycles.com/Models.aspx?ModelID=40480
Cheers.
£12.99.At least I know now.
but I found it a bit of a minefield. The cassettes fit onto a freehub, which is like a barrel assembly that comes as part of the wheel, it has grooves on which the cassette slots into and is then locked down with a lockring. I had bought new wheels, found out that my current set of cogs was a freewheel block after looking at Sheldons site, so then bought a cassette and spacer (which is needed if 7 speed - only a couple of quid), which then meant a new chain aswell
(new chainrings next
