Help! Stuck in an Apple user's house!
The router has no controls on it except the sort of reset button that you need to stick something pointy in. There is also something called an Airport Extreme Base Station, FFS. That has no buttons on it either. I am posting from the iMac that is connected via the router. Thanks for above suggestions, which I will study and see if I can make sense of them. The laptop I wish to connect is an HP elitebook with Windows 7, but the problem is the same for any non-Apple device - my brother's Windows phone, my Android phone, other laptops etc...
Can you post the difference in connection settings between a working iDevice and a non-working computer?
AndyRM
XOXO
North Shields
See if a neighbour has left their WiFi unprotected and nick it.
theclaud
theclaud
Openly Marxist
Swansea
[QUOTE 3284271, member: 259"]The easiest thing to do if you're having problems with access via the router is to share internet access from the Mac.
They need to go into preferences, select sharing, check the box that says internet sharing and follow the instructions to name their wifi share and a password if you want to. Then you can connect to that hotspot[/QUOTE]
Thanks Mort. The internet sharing box is already ticked...
phil_hg_uk
I am not a member, I am a free man !!!!!!
Now you are being (a bit more) helpful :laugh:
On the PC ( I am assuming it is a windows PC ? if not then ignore this ) goto the command prompt and type ipconfig then press the return key and have a look at the settings and it should have been assigned an IP Address, Subnet Mask and a Default Gateway. The Default Gateway should be the IP Adress of the router if it isnt or it is missing this could be the problem.
MacB
Choose your friends more carefully
I'd guess at security in the router or it's on a different channel, I think my Virgin router can be set for 2 or 3 different ones.
phil_hg_uk
Are you connecting to the Airport or the Virgin Media Router ?
theclaud
theclaud
Openly Marxist
Swansea
Thanks Phil. The default gateway is the IP address of the router.
theclaud
theclaud
Openly Marxist
Swansea
It sounds like there are 3 different wifi networks you can connect to: the virgin one, the airport or the one on the iMac. Have you tried all 3?
My laptop finds two wi-fi connections, and the problem is identical whichever I connect to. I assume, after having followed Phil's instructions above, that it is connecting via the Virgin router because it specifies the connection as cable.virginmedia.net
If the imac is sharing it's internet via wifi, you should be able to see that. And connect to it.
phil_hg_uk
What are the symptoms you are getting i.e. I know you can connect to WiFi so what happens when you try to open a website ?
