help with trike ideas
stuee147
north ayrshire
hi all
as some of you will be awear im in the process of designing the next trke build but there are a couple of ideas i have that i would like some feed back on (good or bad )
1st idea is im thinking of having a folding trike but not the normal way where it folds in half lengh ways im thinking of folding the two front wheels in making it a lot narrower and able to fit threw doorways the idea is that i could fold the boom arms along the main boom this will bring the wheels in closer to the frame. in therey i would be looking at having around 28" to 30" wheel track unfolded and with about a 12" track when folded not taking much more space than a standered 2 wheeler.
one thing i have had to consider with the above idea is the track rod it will need to fold like the boom arms the idea i have had is to use a universal joint like the ones you get in a socket set. i was thinking if i weld it onto the track rod and having some for of tubing as a sleave to slide over the universal joint to fix it in place for when riding. any ideas on this ?
another thing i would like advice / opinions on is i have been looking for a supply of headsets/tubes ect for the trike and iv been looking at scooters i dont mean the silly little kiddy ones you can get for a few quid. iv been looking at steel stunt scooters the headsets/tubes look just the same as on a bike but they are about half the size of a bike one which is great as most designs call for the head tubes to be cut down to around 4"
has anyone else tried this the only problem i could see is the thickness of the headtube im not sure how thick or strong it is. apart from that it seems to be the perfect thing its the right size so no cutting and rewelding even the forks are a smaller simpler profile and would take a lot less work to get ready to use.
anyway there the main bits im a bit stuck on at the moment so any ideas thoughts or comments are always welcome
stuee
classic33
Leg End Member
Scooters are a similar thickness as you'll find on a bike. Some of the cheaper ones are actually thicker, not certain if its to compensate for quality or thicker for strengh.
paul fellows
Middlesbrough UK
Stuee
for the tracking rod may I suggest a hinge, as it only needs to bend on one plain. With the middle moving back or forward as you fold the wheels in forwards or back, think scissor lifter.
There have been a few over the years from the venerable "GNAT" to more up to date designs
The most recent addition is the "Edge"
Also not recumbent, but te DiBlasi trikes fold the cross beam as well
The other option is to design a "delta" trike.
There are a few out there, and the trick is that you can arrow the frame width as the wheels can fit behind and under the rider. (Most designs tilt though which is a further complication)
This is the type of thing:
paul fellows
Middlesbrough UK
A ball and socket will have too many degrees of freedom, floppy.
If it was me I would use a large nut and bolt as a hinge.
1] cut the rod in half.
2] stick the head of the bolt to the end of one cut end of rod, at a right angle pointing up.
3] put the nut all the way on to the bolt.
4] stick the other half of the rod to the nut, such that it is in line with the first half of the rod.
5] a spring washer and an other nut will stop it from folding when yo don’t want it to.
cunobelin the tilting mechenizem on that last video is absolutly brillient i will always like ideas like that!!!
stuee
The Evolve trike has the novel idea of using an idler in the middle of the trackrod so in effect a pair of hinged front booms and 4 spherical rod ends would be the easiest way if a compound joint was used the front boom could fold both under , both cross booms fold back using only one quick release bolt and you could still use Under Seat Steering if the ends of the bars folded as well.
regard emma
stuee147
stuee147
north ayrshire
thanks all thats great just what i was after :okay:
@classic33 i think ill have to buy one of the scooters and take it apart and see if i can use it as a chaeper and simpler alternitive to bike headtubes. im not worried if i need to buy better bearings its the tubes and forks that im really thinking of.
iv also been thinking of maybe useing the folding mech on the scooter for the folding boom arms, i recon the design of it would work but im not sure about strengh i think it will be some trial and error, hopfully all i will need do is upgrade the plate the QR leaver locks onto to fold /unfold on either side of the boom it looks to be around 2mm think i was thinking of cutting new ones out of 4mm plate that should be plenty strong enough.
@voyager thats just how i was thinking of follding the wheels in i just hadnt seen it. the only difference i was thinking of folding forwards rather than back the main reason being im planing on building battery / tool storage under the seat like the outlander 422.
im going to have a battery pack in the larger section on either side then i was thinking of having all the electrics and fuses ect in the sloping front section of the boxes on one side and the on the other side i was going to use it as a tool/ storage box.
having said that i do like the idea of folding back and then folding the boom its just so neat and simple
@paul fellows i have thought of a hinge but im worried it may fold during rides due to vibrations bumps ect. thats what made me think of the universal joint with a sleave,
i think i may have confused you and me as to what i wa thinking of using its not a ball and socket its more a universal joint i think im not sure i know what i mean i just get muddled with what things are called
this is the type of thing i was thinking of but i would replace the spring with a sleve that would hold it all straight and tight when in use.
@Wobbly John
that is perfect its just what iv been looking for iv serched for QR track rod ends, QR CV joint, QR universal joint and lots of other variations on lockerbal, ajusterball and QR but now i know what they are called i have found loads of supliers lol.
i think the moral here is that i should really try and learn the names of things lol but then iv always been bad with names i introduced a girlfriend to my sister as my girlfriend once as i couldnt remember her name i mean we had only been going out for about 3 weeks so i hadnt got used to her name yet. for some reason she wasnt very happy i couldnt remember her name but then thats women for you :laugh:
@Cunobelin great vids i like the 1st one i can see alot of the detail on how the fold mech works and have worked a lot out from it i like the way they have the track rod .
also the last video is great iv seen it a few times its such a simple idea but seems to work i think that could be a little play about project just to see how it goes. it apears to have a stearing front wheel as well but its not attached to any form of handle bar or anything it just basicaly flops about that would worry me one pot hole and you would be flat on your back.
thanks again and keep the ideas comeing
stuee
http://data:image/jpeg;base64,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 http://data:image/jpeg;base64,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
classic33
Leg End Member
The scooters tend to be made out of/from an aluminiun alloy, not steel. Apart from the bearing assemblies.
The folding mechanism whilst simple will not take that great a sideways load on it. Possibly due to the materials used. Its one reason the stunt scooters don't fold. The folding scooters have a disclaimer stuck on them.
Want to find out if its steel or not, take a magnet with you when you go to look at one.
stuee147
stuee147
north ayrshire
i have seen most of the scooters seem to be ally but i have found a place that do the steel stunt scooters. i see what you mean about the fold mech they dont really look much to be honest lol
the magnet trick is a great one for finding steel and iv always got a magnet with me just like a lot of people i have a magnet in my mobile phone case that holds the case closed saves looking for a magnet and remembering to take one with me its alway there
Stuee
I can produce a pair of shortened 1" fork tubes and head tubes if you are having a problem making them as I re-manufacture my own shortened ones from scrap head tubes .
I have a die and can produce a pair to your measurements .
PM me if you need a pair .
regards emma
Sandman and I are only 5 miles apart and the ideas that are still in the pot are interesting .
There is still talk of a tandem e-tadpole in the next couple of years . The parts are being collected and I have the 14mm axled 48spoke disc wheels and
we are still looking for 2 pairs of cranks and pedals etc . that project will use about 5 lengths of chain in the transmission
I am lucky that I have a good set of friends with the same "hobby interests " and despite some being a few (hundred ) miles apart we help each other out ..
Ken and I are still cyclists / trikers and it helps having ,several common interests to keep the conversations flowing and formulate new ideas and projects ..
Ken is still using the electric folding shopper as a "commute to work" bike and that is running well since its several little mods and upgrades .
Its is still a "MARMIL eater " in sheep's clothing
In July Sandman ( John ) and I are hosting the Southern Area Zombie Fest a camping weekend in Lancing Sussex for like minded " Zombies " to meet and discuss our projects and get together for a couple of rides and a couple of evenings entertainment etc .
regards emma
