Everyone who had their own generator before mains electricity was available very quickly accepted mains electric when it came along so I think you can take it that private generators are more expensive than mains supply for normal domestic usage.Just a thought again, but reading on here about green ect. Would it be cost effective to have your own generator hooked up to your house, instead of paying the bill for electric? Would the cost of fueling and running it be cheaper?
Maybe with todays new generators they might be efficiant enough?Everyone who had their own generator before mains electricity was available very quickly accepted mains electric when it came along so I think you can take it that private generators are more expensive than mains supply for normal domestic usage.
What about catalytic converters? and maybe just use on evenings or for certain times maybe?It would not be greener for everyone to have their own generator, the emissions from the millions of engines would be very bad. The cost of fuel, maintenance, etc would be higher than what we pay now if we use the same amount of power!!!!!!!!!!!!!!!!!!!!!!
Could it also be used to charge batteries while in use,for later use, so adding to the saving ?you would need a very big generator for a whole house, small ones are very good if you have a power cut
If you want batteries look for pre used submarine and UPS back up batteries. You will need several tons of them and a good charger and inverter. Lots of money.Could it also be used to charge batteries while in use,for later use, so adding to the saving ?
Now that isnt a bad idea, would a battery store enough to power these if, for example, you did an hour or two a day, and give your tv and lappy a couple of hours off the mainline electic?If you work out how much electricity you are using and then looked at the specs for a suitable generator then you may find that it will use a considerable amount of diesel fuel to run it. Even with untaxed red diesel it is likely to be more then your electricity bill is now.
A generator is also not going to be much good if it is running just to power a clock and a fridge one moment and then everything else the next. It's efficiency will be rubbish.
It would make more sense to reduce your electricity consumption as much as possible and also look at energy efficient equipment and consumables in the house.
You could install solar hot water and solar PV but the returns on the PV will be negligable in many cases.
Add a generator to a trainer and pedal power your laptop.
I would say avoid burning stuff to make energy. A steam engine is a minefield of safety concerns.Now that isnt a bad idea, would a battery store enough to power these if, for example, you did an hour or two a day, and give your tv and lappy a couple of hours off the mainline electic?
Now I know this is a leap, but what about mini steam engines too? Could the fuel be cheaper to run those ie wood/coal/coke ? Or even dried peat like blocks with modern ingrediants
