Drago
- The Urban Fringe
They're a commercial product. There's an internal loop that slips over the tap and pulls the cover tight-on so it can't go for a jolly in the wind.
DIY jobbie, or a commercial product? I'd expect one to blow away ... :-/
I always drain the hose after a session down the pub
Plumber here...... You'd be amazed how many isolation valves (both for washing machines and outside taps) are sited so they are inaccessible - behind a washing machine is probably the worst choice ever because washing machines are VERY heavy to move. The insulation around the pipe or tap doesn't achieve a great deal apart from minimising wind chill - the tap will be very close to the ambient temperature even if you put it in a thermos flask it would get cold in 24 hours! After turning the isolator off, open the outside tap so that any water in the pipe or tap can't freeze and expand to split the pipe. You'd be amazed how many people keep the outside tap turned off (usually turned far too hard as well) for fear that it will leak, despite the isolator in the house being turned off![]()
I just found a reminder in my diary: "DRAIN HOSE!". It took me a minute or two to remember why it was there...
Ho ho!I had 'Phone Bill' on my to do list once. Whilst I was trying to work out who the hell Bill is I realised it was a reminder to pay it, not call him.
I remove the hose and store it indoors.If you have a similar setup... drain yours too?
My indoor cut off valve is hard to reach, I cover the tap and pipe with "insulating stuff" so they don't freeze.I do have a cutoff indoors - but the person who put it in put it behind the washing machine - which is a right pain, especially if I need to use it to rinse off the bike after a muddy ride - so it normally stays on but with the insulation on the tap and pipe
@Fastpedaller my DIY insulation had worked for years, even when we had several weeks of big freeze last winter.
Maybe I have been lucky!
