Tom B
- Lancashire
I have recently put some Oxford brand pads in my rear brake, simply because I had them handy when my last set wore out.
Other than being a bit squeeky and not having quite as good a feel the did the job for my hybrid.
However yesterday I was going down one of the bigger local descents (back of Sharnyford towards Todmordem for those that know it) where unbeknownst to me there are currently four sets of temp lights, of course each was on red resulting in 4 big stops from approaching 40mph in the first and over 30mph thereafter. After the first couple of stops the rear lever went hard and the brake was binding. After a mile or two at slow speed on the flat I stopped and the lever feel became normal and the pads freed off.
Now its bugging me as to what has gone wrong. If the fluid had boiled I'd expect soft squishy lever and no or little braking effort. I'm thinking the piston has overheated and jammed until cooled when it was able to retract.
No other issues for the next 40miles including on descents from Heptonstall and into Littleborough from crag.
Either way I'm going to put some shimano pads in and see if that makes a difference.
Calipers and Levers are Shimano m615 with 160mm rotors.
