how far from the kerb?!
adunn01
Glasgow
i don't see myself anything close to a gutter hugger when cycling, i take a position that i'd guess to be about half a metre from the kerb, maybe slightly more. on a decent road surface i'd say i cycle where the third line would be if we had triple yellow lines (think that makes sense!)
I've just been reading a fellow cyclists blog (i won't name him. as if nobody can guess.) where he mentions his normal cycling position is 1 metre from the kerb. this seems like an unbelievably strange standard road position to select imo and i don't see many people taking this position, but it got me thinking that maybe i'm missing something. Am I?!
ianrauk
Tattooed Beat Messiah
Rides Ti2
myself, about the same as you; half a metre... until pinch points and parked cars then into primary
PrettyboyTim
Brighton
Obviously it depends a lot on the local conditions, but about a metre out sounds about right to me. To be honest through so much of my commute is past parked cars I have to stay further out than that.
gbb
Peterborough
Half a metre for me under normal, clear conditions. Next to parked cars, i go to 1metre, and primary only very sparingly.
And so starteth the road positioning arguement ;)
Landslide
Rare Migrant
My rule of thumb is at least one (large) pace away from the kerb (in case a pedestrian steps off it unexpectedly) or if passing parked cars, at least one (large) car door away from the cars (in case a motorist opens one unexpectedly).
Now't wrong with what you are doing.... I do that too - up to 1m out. No 1 Ride assertively - look, signal, move.
The crossings/restrictions on my commute I have less problems with - i.e. the drivers hold back usually - I wave "Thanks".... and this works... i.e Primary.....
But my training rides at weekends are different:-
On one run, out of town, we have some islands...terrible for cyclists..it's not on a major commute route, but it has made my training rides very dangerous...40 mph wide roads.... easy pass of cyclists, then some silly islands.....not funny..
gavintc
Southsea
Travel in the track that a car's left wheel would be travelling. This piece of the road has less crap as the cars have swept it clean and ensures that cars will see you. I think it is called secondary and when approaching a narrow point - eg a traffic island where there is no room for a bike and a car, you need to dominate and I move into the middle of the lane to stop anyone thinking about coming past me.
mr_cellophane
Essex
About that for me. Can't believe the number of cyclist I see who treat double yellow lines like a cycle lane. Much too many bumps and dips that close to the kerb for me.
Chrisz
Sittingbourne
That's about it for me too.
Gutter-hugging invites 'squeeze-byes', leaving you no room to manoeuvre should they squeeze by a little too close!
I don't actually cycle with a tape measure but that sounds about right to me.
gbb
Peterborough
I have a few of them on one of my routes...definately one of the rare times i'll take primary
boydj
Paisley
+ 1 more.
This probably puts me 4 to 5 feet out for my default 'secondary' position on a lot of the roads on my commute, which are mostly reasonably wide. I'll come in a bit closer if the lanes are narrower, but very seldom less than 3 ft out - away from the crap and more visible to motorists - with a bit of 'wiggle' room if required.
A
adunn01
Glasgow
as an update, I tried that whole 1m from the kerb thing to do and it felt ridiculously wide. It was pretty much an encouragement to close over-takers.
I've now convinced myself that the original blogger who I read saying 1m was just over-estimating his distance from the kerb, there's no way that far out is necessary or safer.
wafflycat
My default position is a secondary position, dependent upon width of road, it's about where the tyre track of nearside vehicle would be. If needed, I will take a primary postion in the middle of the lane, such as coming up to a pinch point such as pedestrian refuge. I've found that cycling further out into the main lane away from the gutter means I get more room given to me by drivers and on the odd time someone is a bit close, I've got a bit of 'escape room' to y left, whereas if you cycle effectively in the gutter and you get a close overtake, that 'escape room' is denied you.
To the OP - have a look at the new national cycle training standards...
