Beebo
Firm and Fruity
- Hexleybeef
Anyway everyone knows the plural of goose is goosesExcellent glad I feed your pet gripe you crack on and have a nice day and watch out for the geese.
"can" is such a tricky word to tie downWhy not have both if you can?
I've owned both expensive and cheap bikes. The main thing that makes the difference is stiffness, not weight. Lets be honest the kg difference between a top end and low/middle range bike is probably 2-3kg, most of us carry a lot more in terms of excess body fat, so really bike weight is not that important. The ability to transfer that power to the road is important and cheaper frames just don't do as good a job. However one caveat to the weight statement would be wheel weight, which does make a huge difference in climbing, due to the rotational weight. Climbing on a 1900g wheelset is a vastly different experience from climbing on a 1400g set.
Oh dear, I was wondering when we'd get onto rotational weight. Whether the weight is in the wheels or elsewhere has no impact on climbing. It has a TINY impact on acceleration. I'm sure it feels different to you, but the physics doesn't back it up.
I do agree on the stiffness (ooer missus) however. On short power climbs, it seems that the lack of flex in the frame helps. On long climbs, not really
Spot the scary typoAgreed not much difference in weight between the £1000 and Taliban.
To the O.P loosing body mass will have a much more notable difference.
......... this is why tapering and getting your taper right matters much more for people taking part in short duration and explosive events.......
Hmmmmm.......not sure about this. I may have missed your meaning entirely. Relating it to running: marathon runners taper according to a strict regime starting at least 2 weeks before the event. Sprinters don't.
Yebbut........somehow you seem to be implying that tapering is more important for short duration power events than for endurance events. If that is actually what you are saying, then I beg to differ. If it isn't, then maybe help us out with a clearer explanation.
You forgot loos (aka dunnies, aka Johns, aka... well you get the point) . As for the topic, how much is much? I found that my road bike is definitely easier to ride up mountains than my touring bike, even though I love riding the latter and have done many, many happy miles on it. Each bike has its pros and cons, but 7kg (the difference in weight between my 2 bikes) does make a difference when riding up hills.Pet gripe. Loose = not tight, rhymes with goose. Lose = can't find, deliberately shed etc. rhymes with shoes[/derail]
OK, thanks for that. That is clearer: a poor tapering for a power athlete is proportionately more important than a poor tapering for an endurance athlete (I can't see any way it could ever be worse in absolute terms). However, as counter to that, the tapering for a power athlete is disproportionately shorter and more straightforward than for an endurance athlete, excluding non-tapering issues such as diet.It is more fickle since the short duration performance will vary a lot more over a shorter period of time. Thus the balance between short term and long term stress is harder to manage and get your timings right in order to peak on the right day.
If you consider cycling, not running, for simplicity and since you can measure performance using methods that are objective (power output). If you taper for say a 12 hour TT, if you get it a few days wrong or the balance of intensity to volume is not quite optimal, you may lose (or better put fail to realise?) a handful of watts (relative to your absolute potential peak power) since long duration power decays slowly, if you are a sprinter or pursuit rider, you may end up tens of watts down as short duration power decays quickly, relative to long duration power. Now not only is the absolute power loss potentially larger but over the duration of the event, will have a more severe outcome on the result as the margins in the event are vastly different.
Similarly if you don't taper enough, you are likely to experience greater losses both absolute and relative in shorter duration efforts.
