I can’t be the only one…….
sevenfourate
Devotee of OCD
Hmmmm. A bit miffed 🙁
*Stuck my SPD-SL cleats on the Mavic shoes I was kindly given - this afternoon (My first ever clipless pedals) - to get a feel for what’s going on. Messed around with cleat tension / how the foot is released etc.
And then noticed how darned close my shoe is to the crank arm. [Approx 6mm max I reckon]. At this point shoes are as new / have done very little work / so are not stretched at all. And when pictured there’s no foot or weight in them of course. So that small gap is only going to decrease. I’ll be at risk of rubbing with every revolution……
It’s hardly surprising in retrospect of course. I didn’t pick out when purchasing - how darned short the spindle is on these Shimano 105 pedals.
Just had a half-hour look on the net. And I can’t find too many pedals with clearly longer spindles. Apart from some of the Chinese Brands (Which doesn’t hugely worry me - as I’m sure I have the same [Bearings not bushes] brand on my Carrera and they’ve done 2000+ miles…and run as good as new).
Or of course I could whack a pair of 16mm extenders in line:
Anyone got any thoughts / experiences on this at all ?
4mm gap here and no problems.
sevenfourate
sevenfourate
Devotee of OCD
Don't be fooled by the rock bros picture, the pedal body looks narrow. All road pedals have a smaller gap than MTB SPD.
That’s hugely informative….Thankyou.
You couldn’t have been more spot-on if you tried 😉
They are literally exactly the same width. The ROCKBROS must have a narrower body - as you say. Presuming the spindle is longer: like it appears visually.
Webbo2
Most of my shoes look to have a similar distance to the pedal. I don’t ever recall in 40 plus years of cycling my shoes catching on the crank at the front. However if you have a lot of float you can end up banging the heel of your shoe on the frame especially if you a bit of kicker and gouger in your pedalling stroke.🫣
Gunk
Oxford
Most shoes end up rubbing the crank arms, my son is a pretty serious cyclist/triathlete and both crank arms are already pretty scratched and worn. I’ve found that most serious cyclists are not that bothered with wear and tear as long as bike is quick and reliable.
ColinJ
Puzzle game procrastinator!
A quick look back at the photos of @sevenfourate's various bike projects will reveal that he is not like 'most serious cyclists' in that respect!! :okay:
He found that the definitions of the words 'meticulous', 'precise', and 'perfect' needed tightening up. :laugh:
I have that problem with the words 'careless', 'sloppy', and 'iffy'... :whistle:
The only way that I could go on a forum ride with him would be to get hold of an immaculate rental bike. If I turned up on one of mine he would probably end up riding off in disgust at the mechanical horrors that I had exposed him to! :blush:
Ian H
Ancient randonneur
You can get 1mm pedal washers. They're a good idea to avoid the crank being gouged leading to possible failure. Two is the safe maximum.
sevenfourate
sevenfourate
Devotee of OCD
The only way that I could go on a forum ride with him would be to get hold of an immaculate rental bike. If I turned up on one of mine he would probably end up riding off in disgust at the mechical horrors that I had exposed him to! :blush:
LMAO Col 😁😁
I’m OCD. I don’t apologise. It’s my DNA. It has its benefits (My Boss loves me - I let nothing go with my inbuilt quality control. And not much gets past me). On other occasions it’s likely tiresome to some.
And no ! If we ever ride - you turn up on what you like my friend. I got no issues at all with that.
*Just please don’t be tempted to run your un-washed hands over my Polished, Helicopter taped and then Ceramic coated paintwork……🤣🤣
ColinJ
Overshoes are the worse culprit for doing that.
They definitely were a big part of the problem on the 2 black cranks, which are on my winter bikes. The overshoes wore through where they were rubbing.
The silver cranks are on my best bike which I only rode through 1 winter** so most of the wear came directly from the shoes, which had corresponding wear on them.
** Steep gritted Yorkshire descents kill rim-braked wheels. My winter rides are now on disc brakes!
