Carradice Bagman Utility - anybody tried one?
scotsbikester
This...
Bagman Utility
...I think must be a new product.
Has anybody tried one yet? I keep thinking about a Bagman, and the little attachment points on this look useful, but it's quite a lot more money than the normal Bagman.
a.twiddler
While saddle manufacturers continue to neglect to include saddlebag loops, we're limited to this sort of thing. It's quite pricey for the sake of a couple of loops even if you like chrome. I must be old, but loops were the sort of thing you took for granted on a saddle at one time even if you didn't use them.
I used to use a QR saddlebag frame by Karrimor (pretty much the same as the Carradice one) for years, but despite liking the convenience and traditional look eventually started using a rack top bag. It was a lot slimmer and easy to fit in a garage crowded with other bikes.
I also once had a Thorn bag raiser which clamped to the seat tube and gave you somewhere a bit higher to attach a saddlebag if you were a bit short, or had a loopless saddle, though it was a bit clunky, only about £25.00 at the time though.
When I bought a used Brompton a few years ago, the saddle came with plastic bag loops. I wonder if they still do?
rualexander
Not sure it would be any better than the standard Bagman really.
And it's only rated for 6kg rather than 10kg of the standard (wonder why).
Strange materials description of "high grade metal" then says 304 Stainless Steel, then "chrome plated for corrosion resistance" 🤔
The strap loops might be handy but would be handier if there was a bar with loops across the lower front so you could run straps or bungees to hold dry bags etc. As it is the strap routing would be a bit weird.
