I have joined the 165 club
At my service on 2x12 Giant Revolt late last year the mechanic mentioned a slight buckle on my FSA chain ring...nothing to worry about too much but you need to know it's there. The rest of everything is GRX so I assume the FSA was a cost decision and most Revolt riders report many benefits in changing to GRX cranks . So, Instead of new rings bought a grx crankset and decided to go 165 as, at 5'8 and 30" legs I decided it was probably smart to do that rather than 172.5 like the old one. Rings went from 48/32 to 46/30 and a new BB was needed plus I replaced cassette and chain so a bit of a change all round. I did about 32 miles today, first time out, and on one of my usual slightly hilly routes and really enjoyed the ride and maybe felt a few differences but then maybe it was the sunshine and/or psychology. Either way I am pleased I made those choices .
midlandsgrimpeur
I mentioned similar on another thread. I have switched from 170 to 160mm for reasons of comfort and to help with an existing back problem. Probably the best bike fit decision I have ever made. After a few weeks it is pretty clear I have been riding too long a crank for 20 years!
T
teeonethousand
I mentioned similar on another thread. I have switched from 170 to 160mm fpr reasons of comfort and to help with an existing back problem. Probably the best bike fit decision I have ever made. After a few weeks it is pretty clear I have been riding too long a crank for 20 years!
I don't have any aches/pains at the moment but I am now in my 70s and have noticed that when I get really cold it's my knees that ache first ......so I hope I am future proofing 😁
Overconfidentii Vulgaris
I hope you get on well with it. I tried changing from 170 to 165mm cranks after spending years struggling to find a set up that really worked for me. It became a standing joke that I was always tweaking the saddle adjustment. The 165 cranks seem to suit me and when I need to set up one of the bikes it is a lot easier than it used to be to find a comfortable position. I wish I'd tried it when I first considered the idea about 12 years ago.
Sharky
Kent
An interesting memory ....
When I first got serious, I was riding a Williams C34, steel chain set. Being imperial in those days, cranks were 6.5" , which equates to a 165mm measurement.
Did some good rides on that bike, but I was too eager to switch to a bike with alloy components, which meant 170mm cranks.
I remember the first couple of races I did on the new bike, just didn't have the same "zip" as the old bike.
travellingwest
Sorry to jump on your thread but it seems an opportune moment to ask how changing the crank length affects your riding comfort etc? I am sure this is obvious to those in the know but I am ignorant and just wonder what sort of effect it has on the body position, comfort, riding style/ability etc. TIA
Sharky
Kent
You raise the saddle slightly and the hip and knee ankles are more open. You feel that you are peddling faster in a lower gear, although the pedal speed at the circumference is about the same.
Gave me a feeling of more "zipiness", although this is me with 150mm cranks.
The more open angles at the hip, in theory allow a more aero position for time trialing.
All very minor differences, but worth experimenting.
If still on sq taper cranks, you can get short cranks from the BMX world. A couple on mine are Sinz Expert cranks. Also have a couple that were re drilled by highpath engineering.
Another benefit, helps to mitigate against toe overlap and if on fixed, a bit safer when cornering.
T
teeonethousand
I watched a bunch of YouTube videos on it....GCN did a particularly good one. I am sure it depends massively on your personal biomechanics and your riding goals but worse case it can't harm a shortie like me.
170mm here. They will be back in fashion again soon. Same with bar widths. Two classic road bikes with relatively narrow bars, then in came wider road bars, and now we have UCI regs stopping people going narrower still.
Doesnt. I ride 170mm on three bikes (road and gravel) and 175mm on the two MTB's.
Can't tell the difference in 5mm. Now 150mm might.
For the average rider it's not worth the hassle. Now if you are winning races every weekend, then there may be a marginal gain.
Erm different bike, so may not have been the cranks.
