It certainly wasn't a dig at you!
Being a failed tech bro I've always been into the joins between cycling and tech so was a relatively early adopter of electronic group sets, and yes it was Shimano Di2. Since then I've had another Di2 equipped bike (a TT bike), refitted my original Di2 groupset to another frame post-collision and now my latest bike is fitted with SRAM Red eTap AXS, so I've got an opinion for sure. For balance my old-reliable has had various mechanical Shimano groupsets fitted and I've even got a Rohloff flat-bar tourer if we want to do derailleur vs hub shoot-off.
I really had been meaning to open a thread like this for a while because, while some of the criticisms are valid, I think there's an element of groupthink across the forum that has a whiff of the old git about it. I'm lacking the time to go full Benstead on the subject so here's my TL;DR;
Gearing in general - different strokes for different folks. Different solutions work for different disciplines and budgets.
Electronic gears in general - more reliable and tougher than you think. Great indexing and shifting consistency. Shifting up to big ring easier 😜. Can customise shifting - i.e. let the software manage big ring shifts. Too expensive. Needs some standard/open protocols. Requires charging. Problems generally can't be repaired in the field. Diagnosing problems can be difficult. Obsolescence more of an issue ATM.
Mechanical derailleurs in general - not as reliable as you think (looking at you brifters!). Modern indexing is good but can be tricky to set up. Cost-effective. Some ability to repair in the field and diagnosing issues usually easier.
Shimano Di2 - first viable electronic groupset. Single battery solution gives loooong battery life but can't be charged away from bike. Great shifting performance. 4 paddles for shifts is very flexible and configurable. Wired (or partially wired) system increases damage risk and reduces reliability IMO. Typical garbage Shimano documentation. Awful software. Shimano closed protocols (see recent hammerhead integration issue).
SRAM eTap - Absolutely no wires. Double battery solution requires charging more frequently but can be done away from the bike - very neat. Had zero problems with water-ingress etc. Also great shifting (maybe slightly less good than Shimano?). Two paddle shifters are less flexible and "double tap" not for everyone. Documentation much more consumer focused and better software. Better and easier 'soft' configuration options. Potential for more open and standard hardware/software stack. Confusing product lineup and inter-generation compatibility.
Campag eps - 🤷♂️
Rohloff - "wow, you fitted a coffee grinder to your rear wheel!"![]()
Didn't Campagnolo solve that issue 20 years ago with Chorus and above. Edit. Just the same in the mountain biking with XT And if you could afford it XTR. 😄As someone who has Di2, eTap, Mechanical Force and Mechanical 105 on their fleet I agree with this. I will add that electronic shifting on a bad weather bike has been a revelation, it just works, no cables to seize up.
As a software engineer and system administrator in a previous life, it's a matter of principle for me. Bicycles don't need software, so I won't have ANY of that CRAP on one of mine. It's ok for speedometers, and yes, I have a 'smart' phone, and appreciate modern medicine, etc.
I don't care who else uses software on their bicycles, btw. I just won't, myself, because I know a lot about........software.![]()
We have a non-electric door-bell.Having worked in IT myself, I think I'm much the same; I try to avoid it where sensible in my normal life!
But it's all about what's appropriate for a specific circumstance: electrics work well for a handlebar GPS (but paper is better for backup maps). I always knock on doors before searching around for a doorbell. Internet works well for forums, email, searching for obscure info or purchases, interactives stuffs ... but radio waves work best for music in my kitchen.
etc etc ...
And you can't beat a physical hug!!!
Of course that's assuming your LBS has the skillset and parts to do so... which if nothing else are likely to be far more affected by supply chain issues since it's all still relatively niche and propriatory; unlike a length of cable inner for example which will fit pretty much any mech.As for everyone saying that they'd rather stick with mechanical because it's easier to fix; that's all well and good for those of you who are capable in that regard, but for people like me who are inept at that sort of thing, if my gearing failed on a bleak and windy moor, I'd be having to get a lift to the nearest LBS regardless of it being mechanical or electronic!
This is a forum comprised mainly of people well past their youth, who remember a "Golden age" when things were better, cheaper and simpler. They were not, of course. Just that we were young, fit, in our prime, and that's where our best memories are.
Change is driven by the young, to whom charging equipment is second nature because that is what they've grown up with and who don't give a rat's arse about antiquated frame materials, down tube shifters and brooks saddles.
Every innovation in bicycle has been met with fierce opposition, as anyone who was around when a sixth sprocket was added to the back wheel will tell you. Thank the lord for the innovators and the early adopters who ignore the old coffin dodgers of every generation, because without them we'd still be riding penny farthings with solid tyres.
Indeed, although there's an important differentiation between change that's driven by genuine improvement / legitimate necessity, and the need to change for the sake of it to keep people buying..
Faster, more precise gear shifts are important to those who ride competitively, whether that's with a number on their back, in a sportive or just out for a fast ride with their mates.
You don't have to have it, mechanical will still be around long after all here have gone. Those who buy it are not doing so because they are gullible or have more money than sense, but because it suits their requirements.
, I have two broken example brifters in my parts bin - Ultegra and Dura Ace. The Ultegra seems to have some snapped internal plastic and the Dura-Ace I think has lost a spring. I also have a "repaired" Ultegra where a return spring had popped out but I was able to reseat after a good deal of swearing. Bear in mind these are regarded as not repairable by Shimano. I'd recommend looking inside a brifter if you get the chance. Alongside some mechanical complexity, a lot of the plastic is no better than decent toy grade. Even at the top end, they're built to a price. They might be more reliable than a pair of microswitches, but then again they might not.
