classic33
Leg End Member
jimboalee said:As a matter of fact, there are several parts if the train that are moving backwards![]()
Only seven. What type of trains do you use??
Yellow Fang said:Newton's first law:
"Every object persists in its state of rest or uniform motion in a straight line unless it is compelled to change that state by the forces impressed on it."
The train is moving at X mpg, you're moving along at X mph, the air in the carriage is moving at X mph, so there's no friction. Therefore you're going to land exactly where you were on the train.
jimboalee said:Deadly serious ???
1 day = 1 revolution of the Earth on it's axis.
This is the only measurement of time we need to be concerned with.
Norm said:Gravity sucks, downwards. It will define the arc of the jumper but it will not affect his speed relative to the train or the air around him.
classic33 said:Only seven. What type of trains do you use??
jimboalee said:Shall I start another thread, or pose the question here?
Tollers, figure this?
When you buy a mechanical wristwatch, it SLOWS down as it 'runs in'.
How does this happen if the bearings are polishing and it should run easier?
IT'S RELATIVE!!!!!!!!!!
