Drago
- The Urban Fringe
Thats probably not an unreasonable piece of advice.
quick google says the dft says if you can do more than 18 mph you should consider using the road rather than shared use paths
I say if you do not want punctures and your fillings to fall out you should consider using the road rather than (many, but not all) shared use paths.
I have to use one for part of my commute as im not chancing a 40 mph 3 lane roundabout roundabout where its dodgy enough in a vehicle with everyone playing dodgems ( i speak from experience of driving it ) and i get more flats on the one mile section than i do the rest of the year riding .It is 250 watt continuous output, maximum. No mention of 250 watt peak power output in the regulationsIm talking about maintaining easy comfy pace for an amateur. The power is peak of the motor not consistent power delivered.
Bear in mind you would need towards 500 watts to maintain a gentle 6mph on a 20% hill.
I know from experience we have a steep hill of 12% average gradient. I used to die a thousand deaths trying to cycle up on my regular non assisted bike. I can now climb it in comfort maintaining a speed which allows stability.And 300W will give you 4mph, requiring a mere 50W contribution from the rider to a 250W limit. 250W will still give you over 3mph - walking speed. And remember that the 250W value is continuous rated power, not peak.
Go from two to three wheels if stability is really a problem.Those speeds are wobble, fall off.
Now consider how incredibly rare 20% hills are. I don't mean hills that cyclists say are 20% but which are really 15% - there are hundreds and hundreds of those. Actual 20% stretches are short and infrequent.
250W is enough assist for anyone who wants to undertake any normal cycling in the UK. If you want a bike that puts you on a par with trained cyclists, without you having to put in any effort at all then what you want is an electric moped, not an EAPC.
