Set myself the task of getting the boy's new bike properly set up for him tonight. Got as far as installing new brake cables etc but have since uninstalled due to a frustrating issue with the set up.
The levers are taken from my CX bike and are inadequate in a few ways. Firstly, the bars are obviously a narrower diameter. Not the end of the world though, I've got some plastic shims that came with some clip on aero bars and they fit nicely.
The main issue is that the levers are just too close together... because the cables move outwards when the lever is depressed, the cable threaded closest to the stem face plate will always push against the cable going into the opposite lever - resulting in that brake applying itself...
A picture probably shows the issue better than my description... (attached). See how the cable from the lever I'm not pressing is being pushed and the affect on the lever...
So is there anything I can do to set these up better? If I move them any wider, the bars narrow so much that the shims become useless and the hand room is restricted. I could maybe set one lever higher than the other to try and make the cables miss, but this would then be awkward for my son.
Any ideas????
Any ideas????
