Is an inner tube an inner tube?
smutchin
Cat 6 Racer
The Red Enclave
Blimey, they are cheap.
As for quality... don't know, but they can't possibly be any worse than Specialized inner tubes, which cost a lot more than that.
ianrauk
Tattooed Beat Messiah
Rides Ti2
I actually thought about buying some of them yesterday, but stuck with the Continentals. There are a couple of poor reviews.
Alexvs
Milton Keynes
I bought these a little while ago and they were then £9 for 6 which really was a bargain. Since using them I was getting through one on each ride whether long or short and always on the same tyre, the front one. I've now had a puncture on all 6 of them and think the longest lasted about 130 odd miles over 2 rides where I think I got lucky. I repaired one the other night with a Park glueless patch to find it was flat by the morning again and so tried pumping it up again to leave over night outside of the tyre and it exploded on me. I won't be buying these or the Park glueless patches again as they both seem useless and worse as a combination.
The whole time I got through this pack of 6 I've had the same continental tube in my rear tyre which I would've expected to die at some point through all of these punctures I was picking up. I also changed from my Michelin Pro 4 tyres I was running to my stock Specialised Espoir tyres thinking it was an issue with the tyres which doesn't seem to be the case after getting further punctures since changing back.
It may be a case of a bad batch or I've been unlucky but either way I've never had so many punctures using other tubes. Think I'll be going with the Specialised pack at Tredz to replace them unless any other deals on branded tubes come up.
Rob3rt
Man or Moose!
Manchester
LOL! What did you expect?
ianrauk
Rides Ti2
How did you apply the patch?
They work perfect if you use them correctly.
