Is it possible to freeze Guinness
philipbh
Spectral Cyclist
Out the back
Or should I ask - is it possible for Guinness (Canned) to freeze at the bottom of a fridge (assuming the thermostat has been turned up to 11)
threebikesmcginty
Corn Fed Hick...
...on the slake
Don't know about tins of Guinness but I have forgotten about bottled beer I've been shock cooling in the freezer and come back to a very lumpy looking drink.
BrumJim
Forum Stalwart (won't take the hint and leave...)
Guinness contains alcohol, so shouldn't freeze until it gets well below zero.
If it does freeze, I presume that it would go the way of any fizzy beverage - flat and horrible.
It is mostly water but the alcohol will lower the freezing point.
There are two areas -
What happends to the drink itself
What happens to the can
As Frozen water is a fair bit bigger than the water that made it I think it should pop the can open unless the can expands out a bit to take it.
U
User169
The can will presumably be under pressure which should lower the melting point a bit.
I kept a can of lager in the freezer a bit too long over the weekend. The contents were liquid until I opened the can at which point they started to freeze, so I ended up with a slush puppy type affair. I've seen the same happen with bottles too.
threebikesmcginty
Corn Fed Hick...
...on the slake
Without wishing to cause offence - it's rubbish stuff in the first place :rolleyes:
Nick_B
When I leave beer in the freezer for too long (just aiming to speed up the cooling) the bottle top gets pushed off causing a sticky mess and much nagging.
