GuyBoden
- Warrington
Hopefully, the more I weigh, the slower I will be riding, thus enjoying the scenery more...............
No-one is going to use knobblys on a 50 mile ride.
Not quite 50 but close,Ok. Certainly leaves me with zero room to infer whatsoever. The edit kind of backfired it appears. Feels free to unedit accordingly.The 'unusually' was an edit, though quite a quick one, as I thought without it I was being harsh (for the season of good will). Please infer what you prefer.
This was the scenario I focused on (quote from the OP):
That is: on the flat, same aero drag (ie position) - just different weights of bike.
Ewwww! Naughty step for ‘trousers!@Bollo have you got your "proper cyclists don't ride expensive bikes" jar? I have a deposit I want to make.
No not that sort of deposit.
Acceleration due to gravity is independent of mass. You must know that.![]()
Your choice of bowling ball and feather is a poor one because they have different cd as well as different mass.
Insomnia edit. But you do have a point. For two riders of identical CD the deceleration due to drag will be inversely proportional to mass. So a heavier rider will experience the same drag force but less deceleration. How significant this is I don't know. Hopefully I'll get to sleep before figuring it out.
I did get to sleep in the end. With thoughts of frontal area and terminal velocities buzzing around in my head.
That's pretty much what Galileo worked out, long before bicycles were invented. If you dropped fat me off the Tower of Pisa together with skinny Chris Froome, we'd hit the ground at the same time - ignoring air resistance. And if you account for air resistance, Froome would get down quicker.Additional weight is of no benefit at all going downhill.
Yes, there's greater momentum going into the flat.As I understand it the main benefit a heavier cyclist has going downhill is the momentum carried as the road evens out. That's certainly where it's very noticeable to me as I (as a relative lightweight) having to pedal to keep up whereas my heavier riding buddies carry their momentum better coming off the decent.
I'm a well-built person who rides steel bikes, but I haven't noticed any speed advantage going downhill.Why do well-built people on steel bikes always seem to descend relatively quickly, then?
This is a bit sloppy
D = drag force (it changes based on several factors including velocity but I think for this we can say it is constant)
I don't know anything about aerodynamics though
