BADGER.BRAD
- Shropshire
Just found this from Wiki
European Union
[edit] Defined
Electrically-assisted cycles are usually classified as either pedelecs or e-bikes. Under European Union regulations adopted in the UK in June 2003, only power-assisted cycles meeting the pedelec classification are considered to be pedal cycles. The maximum power allowed in the European Union for (pedelec) electric bicycles is 250 W, with a maximum assisted speed of 25 km/h.[sup][17][/sup] To meet the pedelec specification the electric motor must be activated by the rider's pedalling effort and the power must cut out completely whenever the rider stops pedalling. Control of the motor by pedalling is often the key difference between a pedelec and e-bike.
A new European product safety standard EN 15194 will be published in 2009. EN 15194 contains several new requirements for ebikes to be sold in European Union and European Economic Area, including weight and voltage limitations. EN 15194 also defines a specific name for EU approved electrically-assisted cycles, EPAC - "Electrically Pedal Assisted Cycle".
Earlier UK regulations required that the motor has an average power output limited to 200 W (250 W for tricycles and tandems) and weight limited to 40 kg (60 kg for tricycles and tandems). These regulations must come in-line with the EU regulations by (find deadline). For models sold before June 2003, e-bikes conforming to the speed, weight and power limits may also be considered pedal cycles. Electric bikes with higher power outputs, or those not meeting the "pedelec" definition are now treated as motorcycles and require a license.
European Union
[edit] Defined
