Surely for converting miles to Kms the simplest way is to divide by five and multiple by eight(*)?
Not for my simple brain. My method - although a bit convoluted - only involves dividing by 2 (easy), dividing by 10 (very easy) and addition (easy). It works in both directions and is good to a few percent.
km = (mi/2) + (mi/10) + mi
mi = (km/2) + (km/10) (plus a little bit for luck)
Now, if I asked my brain to divide by five, and multiply by eight, it would struggle. I'd end up getting out a calculator probably.
Then again the meter is just a random measure that some royal ass made up because he had tiny feet.
The history of the metre is quite interesting.
They were going to make it the length of a pendulum with a period of 1 second. But unfortunately that wouldn't work. Then they decided it would be 1/10,000,000 of the shortest distance from pole to equator (via Paris, natch) But that's not actually useful, seeing that it's an incredibly hard thing to measure. They had a go and said "voila! here's the metre", and everyone had to believe them. It's not like anyone had the ability to disagree.
And so it ended up being the length of a bit of metal in Paris. So after all that it might as well have been some
random measure.
Now it's defined in terms of the speed of light. Which is in fact harder to measure than the circumference of the earth. So unless you have a really good stopwatch and fast fingers ... it's just some
random measure.
And imperial length units are defined in terms of metres. So they are just some
random measure multiplied by some number.
It's all a bit random when it comes down to it. And what is "best" is whatever you happen to be used to.
Interesting fact: A byproduct of the fact that the metre almost defined by the seconds pendulum is the fact that g, the acceleration due to gravity, is almost-but-not-quite pi squared.
