KMC chains. A quick question.
Paulus
Barnet,
I have bought a KMC chain to replace a worn out campag 10 speed on my steed. It has the quick link to join it. Does the chain split in the normal way as I have to shorten it by a couple of links?
battered
Yes, AFAIK you can push out a rivet in the usual way to get the thing to the right length.
Moodyman
Yes, to make doubly sure.
I replaced my worn out SRAM chain with a KMC one. It came with a Powerlink, but I preferred to use the traditional 'push pin out and re-join when I got the right length' method.
Chrisc
Huddersfield
fossyant said:
KMC quick links are very good.....
MINI HIJACK
Might very well be a dumb question BUT here goes...
If you needed a couple of extra links, having say, changed the cassette from 12-25 to 12-27, could you use two quick links, should you fit a new chain, or would it be OK using the same chain length for just two extra teeth?
Chrisc said:
MINI HIJACK
On my utility bike I changed the cassette from a 11-34 to 11-32 and was advised not to change the length of the chain. IIRC technically it should be 1/2 a link shorter. The forum was right I've not had a problem with it.
Using the same logic your chain would technically need to be 1/2 a link longer; your existing chain length will be OK. With a new cassette though you should fit a new chain, although the number of links will be the same as the old.
Riding in Circles
EDINBURGH
Unless you actually used a new deformable pin for this, you now have a weak point on the chain.
Riding in Circles
EDINBURGH
Chrisc said:
MINI HIJACK
Yes you can use two quick links but you need to space them apart.
Globalti
Does anybody know if you can buy KMC quick links? I was separating a chain recently, thinking "mustn't lose the link" when the end of the chain dropped, whipped round... and that was the last I ever saw of half of the link despite searching the garage!
