lazer bond / 5 second fix glue?
steve50
Disenchanted Member
West Yorkshire
raleighnut
I've used UV set superglue in shopfitting, good if you need to get something positioned correctly before 'zapping' it like handles on glass display cabinets
GM
I don't know what you're using it for, but for sticking small things I'd recommend this.....
What ever you do, don't get on your skin!
screenman
I use an LED uv torch for curing my resin, it is a bit better than the one shown. Thing is the resin will only cure where the UV can get to it, so sticking 2 things together is unlikely to work well.
Loch side.
That makes sense. What sort of application is it used for then? I can't think of an adhesive application where the adhesive won't be in the dark.
