Yep, the dengie one on the same day is nearly full,
Yep Dengie one right on my doorstep can cycle to & from the start of that one , can't decide on the Dengie one or the tour of Tendring event , sure entries close for Dengie on Saturday
I've asked about and no one has the answer, everyone who I know with strava premium has a garmin they use it on, so Steve looks like your the test pilot, by the way are you doing the very flat tour de tendering this weekend
Sunday 15th, £20 pay on the day, food stops , medal etcWhat day is the tendering ride? If it's Sunday and there are spaces left I may be up for that. Busy on Saturday though.
Ah brilliant may just do this. Not sure about the 60 miler only ever done 34 miles at a time not sure I am ready to double it in one hit.Sunday 15th, £20 pay on the day, food stops , medal etc
http://www.bike-events.co.uk/Ride.aspx?id=523
I decided to purchase ones of these today £19.99 so thought it was worth a punt bearing in mind the one I nearly purchased the other month was £30.
Not a bad looking package and to be honest it looks the same as many of the other brands out there.
Taking everything out of the box you get you normal bag of bits including zip ties rubber band small foam pad magnet for spoke and pedal and a battery. Also Inc is a tiny Christmas cracker screwdriver. View attachment 126953
Fitting is pretty easy just needing to make sure the speed sensor is lined up with the magnet and the same for the crank which is easier as it has a larger surface area.
There is an app you can download which is pretty basic made by brivit I think. I tried it just to make sure the sensors work and they did.
Now was the real test to see if strava was happy to read the sensor. Opened up strava went to record a ride and clicked the little triangle image on the right. Did a scan and picked it up straight away.
During the ride as the phone was in the saddle bag I had no idea if it was recordng but on the first pit stop I checked and I had an avg 60rpm so it was working fine.
All in all for £20 it does what I wanted I have a bodged phone bracket I am working on using bits and brackets from a go pro kit a phone case and a tripod gopro mount will get a picture once it's all fitted.
It's is only a standard bluetooth option not Ant+ compatable so not sure if it would connect to your garmin as most garmins connect via ant+.curious, has anyone connected this to
Garmin Vivoactive HR?
If you device will allow it it could be worth a try but I tried to pair it with a garmin edge 25 and it wouldn't pick it up.
WAHOO app is the best to see exactly what you are doing whilst out on the bike as Strava will only average it out.many thanks Steve
got it and shall try, if I could connect via wahoo then strava, it is certainly worth the punt as it cost £11.99 ... I shall take it out for a spin this weekend & report back when I can.
I picked up one of these at the weekend 30% off or something so it was £8.40 but i cant fit it my chain stays curve in towards the wheel so there is not enough space for the sensor arm, the spokes brush it before I even fit the magnet to one. Anybody want it?
