tincaman
- Chudleigh, South Devon
The Meteor has a power indicator which flashes red when near the cutoff mark, keep an eye out for this
Our transit system gives us those, along with the public radio station.I carry a handful of these just in case
Hmm. The power indicator flashes red (indicating, I think, under 20% power remaining) after approximately 10-15 minutes of running. It will then run on high power for another hour. It's just not a reliable indicator, but thanks for the suggestion.The Meteor has a power indicator which flashes red when near the cutoff mark, keep an eye out for this
At this time of year, I am in full dark both ways for the full commute. I have a regime of charging every day I use them, both ends, so running out of juice shouldn't be a problem. I think the ultimate solution will be a light with a 3-hour burn time, but that is unlikely to be as small and cute as the Moon. Swings and roundabouts.
I've just looked at the runtimes on the box from my Moon light. All values are "up to"
Constant beam:
Low: 6 lumen - 9 hrs
Standard: 12 lumen - 4 hrs 30
High: 25 lumen - 2 hrs 15
Overdrive: 50 lumen - 1 hr
10% flashing: 5 lumen - 20 hrs 40
50% flashing: 25 lumen - 4 hrs 25
100% flashing: 50 lumen - 2 hrs 10
Strobe: 10 lumen - 10 hrs 40
At constant beam on high you would get a couple of hours, that should do you?
I've had my front light go out once on me (cable fault) but to be honest it's no great shakes as long as you have a back up. Unless you are bowling along at 40+ you can stop the bike in a few seconds. Either carry a spare light (or in my case a spare battery), or buy a light with a longer burn time.
Don't your LED lights have a less powerful setting? In that mode they actually strobe extremely fast so power use is reduced considerably.
Constant beam:
It's the 'protection' circuit on the L-ion batteries that causes it, if the battery fully discharges it wrecks em.
Try getting a light that runs on 4 AA batteries and run that on NiCad or NiMh rechargables (or even Duracells)
EDIT - Try something like this, 80hrs runtime on Alkaline so should give 50-60 on rechargeables
That is an excellent idea.One of the things I quite like about my fenix is that as the power drops, it steps down a light level to maximise run-time.
