Look Keo cartridge bearings - serviceable?
Globalti
I think the castellated removal tool is the same one I have for the cartridge bearings on my SPDs but can Look Keo cartridge bearings be adjusted to take up play?
Gerry Attrick
Sure can.
MrGrumpy
Huge Member
Fly Fifer
what is this removal tool ??
My look keos are poorly.
The Look tool is red : http://www.wiggle.co.uk/p/cycle/7/Look_Cromo_Axle_Assembly_Removal_Tool/5360018170/
Dunno if the SPD one is actually same fit.
But you need the Look tool for KeO Classics and Sprints, Carbons you simply need a ring spanner for.
Remove pedal from bike and put into vice/workmate, then turn tool appropriate way - for no reason I can imagine, the Look tool has direction arrows saying which way is tighten and loosen on the left and right pedals, but it's on the the face-down side when you're using it...
I've not actually had the bearings out of the pedal but have removed the axle, regreased and put it back in - major improvement !
Globalti
Globalti
The Look tool is red : http://www.wiggle.co...ool/5360018170/
You were right Andy, it's not the same. The Look and Shimano castellations are spaced differently. Shame. Off to Wiggle I go.
